Nombre de messages : 3 Age : 37 Localisation : Cardiff Date d'inscription : 21/01/2008
Sujet: Brompton Users - Questionnaire Lun 21 Jan 2008, 22:08
Hello,
My name is Elliot. I am doing a project for Brompton Cycles to develop a multitool to attach to there bikes. If any of you have time would you please fill out a questionnaire for me, it is vital research in the development of the product.
Please copy and paste the questionnaire into your reply and fill it out:
Questionnaire for Brompton Users
Q. Which Brompton model number do you currently own? E.g. M-type... M2L-X • S-Type... • C-Type... • M-Type... • P-type... • Other...
Q. How long for? Please indicate with a X... • 0-6 months • 6 months – 1 year • 1-2 years • 2-5 years • 5 years +
Q. What problems or breakdowns have you had with your Brompton cycle?
Q. Did you own the tools to fix these problems?
Q. If you did, did you carry them on your bike in case of emergency break downs?
Q. Do you perform maintenance on your Brompton yourself or take it to a bike shop?
Q. If you do perform it yourself, how often do you do it?
Q. What tools do you require to do the work?
Q. What is the hardest maintenance or most time consuming task?
Q. How often do you get a puncture?
Q. What Brompton accessories do you own? E.g. front panniers
Thank you, your time is appretiated.
If any body knows of any other Brompton forums would you please tell me.
Elliot
www.EJTannerDesign.co.uk
elliot tanner Novice
p.s. Sorry I cant speak French. I hope you can understand my english.
Thibe Vénérable Grand Maître
Sujet: Re: Brompton Users - Questionnaire Mar 22 Jan 2008, 07:47
elliot tanner a écrit:
Hello,
Elliot
Traduction libre (revoyez-la si je me fourvoie totalement ou si une phrase devait être totalement inintelligible)
Salut, Je m'appelle Elliot. Je suis occupé à plancher sur un projet pour la société Brompton, projet qui consiste à développer un outil multi-fonction que l'on pourrait fixer sur le B. Si l'un ou l'autre d'entre vous a un peu de temps à perdre, pourriez-vous remplir le questionnaire qui suit, c'est une recherche vitale dans le cadre du développement du produit en question.
Merci de "copier/coller" le questionnaire dans votre réponse et de le remplir.
Questionnaire pour les utilisateurs de Brompton
Q. Quel type de B possédez-vous ? [ndt : je vous passe les détails, chacun est assez grand pour comprendre !]
Q. Depuis combien de temps ? 0-6 mois 6 mois-1 an 1-2 ans 2-5 ans 5 ans et plus
Q. Quels genres de problèmes ou de panne avez-vous rencontrés avec votre B ?
Q. Possédiez-vous les outils qui permettent de réparer ces pannes ?
Q. Si c'est le cas, les transportiez-vous sur votre vélo en cas de panne urgente ?
Q. Entretenez-vous vous-même votre B ou le confiez-vous à un vélociste ?
Q. Si vous l'entretenez vous-même, à quelle fréquence le faites-vous ?
Q. De quels outils avez-vous besoin pour ces entretiens ?
Q. Quelle est le type d'entretien qui est le plus difficile ou qui vous prend le plus de temps ?
Q. A quelle fréquence faites-vous face à une crevaison ?
Q. Quels sont les accessoires B que vous possédez ? (pannier, etc.)
Merci pour le temps que vous prendrez à répondre à ce questionnaire.
Si l'un ou l'autre d'entre vous connaît un autre forum consacré au Brompton, merci de m'en informer.
Elliot
marcb Maître Bromptoniste
Sujet: Re: Brompton Users - Questionnaire Mar 22 Jan 2008, 12:10
Ce serait plus simple si les questions étaient numérotées...
Bon, je n'ai encore jamais fait la moindre réparation sur le Brompton. 8)
Sujet: Re: Brompton Users - Questionnaire Mar 22 Jan 2008, 12:19
Plutôt que de râler, édite le message et numérote-les... je vois mal pourquoi ce serait plus simple à vrai dire.
Sujet: Re: Brompton Users - Questionnaire Mar 22 Jan 2008, 14:16
Q. How long for? Please indicate with a X... • 0-6 months • 6 months – 1 year• 1-2 years • 2-5 years • 5 years +
Q. What problems or breakdowns have you had with your Brompton cycle? the rear mudguard
Q. Did you own the tools to fix these problems?no
Q. If you did, did you carry them on your bike in case of emergency break downs?N.A.
Q. Do you perform maintenance on your Brompton yourself or take it to a bike shop? myself
Q. If you do perform it yourself, how often do you do it?every otherweek
Q. What tools do you require to do the work?none clean and lube
Q. What is the hardest maintenance or most time consuming task?full cleaning
Q. How often do you get a puncture?none
Q. What Brompton accessories do you own? E.g. front panniers none
Sujet: Re: Brompton Users - Questionnaire Mar 22 Jan 2008, 14:18
Ca évite de répéter à chaque fois les questions.
Sujet: Re: Brompton Users - Questionnaire Mar 22 Jan 2008, 14:22
On peut aussi envoyer sa réponse en PM à Elliot...
Sujet: Re: Brompton Users - Questionnaire Mar 22 Jan 2008, 14:28
Hello,
1Q. Which Brompton model number do you currently own? E.g. M-type... M2L-X • S-Type...
2Q. How long for? Please indicate with a X... • 1-2 years
3Q. What problems or breakdowns have you had with your Brompton cycle? Problem: cracks in left folding pedals.
4Q. Did you own the tools to fix these problems? No; ride like that; French importer considers that it is not a problem.
5Q. If you did, did you carry them on your bike in case of emergency break downs? No
6Q. Do you perform maintenance on your Brompton yourself or take it to a bike shop? Myself.
7Q. If you do perform it yourself, how often do you do it? Once to twice a month.
8Q. What tools do you require to do the work? Pomp, soap, lubricant.
9Q. What is the hardest maintenance or most time consuming task? Nothing hard (I have never fix a flat).
10Q. How often do you get a puncture? Never
11Q. What Brompton accessories do you own? E.g. front panniers S-Bag
Sujet: Re: Brompton Users - Questionnaire Mar 22 Jan 2008, 17:01
C'est bien souvent ainsi, l'anglais est devenu la "vulgate" de notre époque... "O tempora, O mores", comme disait l'autre... ;-)
Sujet: Re: Brompton Users - Questionnaire Mar 22 Jan 2008, 19:18
• M-Type...
• 2-5 years
flat tire
yes
yes
I do it myself
inspection every week, lubrication depends of weather every 2 weeks-every month
15mm wrench, screwdriver, tires levels, ...
to repair a flat tire on back wheel
1 time every 1000km...
touring pannier, bar-ends, brooks saddle,
Patid Novice
Nombre de messages : 6 Age : 68 Localisation : Bruxelles Date d'inscription : 22/01/2008
Sujet: Re: Brompton Users - Questionnaire Mer 23 Jan 2008, 14:45
Q. Quel type de B possédez-vous ? [ndt : je vous passe les détails, chacun est assez grand pour comprendre !] 3 vitesses, sans porte bagage (modèle intermédiaire anciennement)
Q. Depuis combien de temps ? 2-5 ans : depuis 2003
Q. Quels genres de problèmes ou de panne avez-vous rencontrés avec votre B ? aucun
Q. Entretenez-vous vous-même votre B ou le confiez-vous à un vélociste ? à un vélociste
Q. Quels sont les accessoires B que vous possédez ? (pannier, etc.) un sac 24 litres. Une housse de protection. une selle Brooks (marquée Brompton), un chariot de selle.
seb69 Vénérable Grand Maître
Sujet: Re: Brompton Users - Questionnaire Jeu 24 Jan 2008, 10:40
Hello Elliot & welcome to the french
Hello,
Q. Which Brompton model number do you currently own? E.g. M-type... M2L-X • S-Type... S6L+ • C-Type... • M-Type... • P-type... • Other...
Q. How long for? Please indicate with a X... • 0-6 months • 6 months – 1 year • 1-2 years 15 months • 2-5 years • 5 years +
Q. What problems or breakdowns have you had with your Brompton cycle? Link with hub. Need to change it because didn't move very well. Take off the rear light, 1 led off. I add the Reelight
Q. Did you own the tools to fix these problems? Yes, I have got some tools with me.
Q. If you did, did you carry them on your bike in case of emergency break downs? Yes I do. I've got small box with some tools to take off tires or other....
Q. Do you perform maintenance on your Brompton yourself or take it to a bike shop? Usualy I do it myself but if it's too difficult go to bike shop.
Q. If you do perform it yourself, how often do you do it? 1 time / week usualy
Q. What tools do you require to do the work? >>Click here<<
Q. How often do you get a puncture? Before with the Stelvio tires 3 or 4 times by months Perfect tires but too sensitives Now with the Marathon + 0 after few weeks. Too heavy tires please need other!
Q. What Brompton accessories do you own? E.g. front panniers I add the ends bar, change handful foam, S bag, Reelight, tires from Schwalbe Marathon +
Elliot
Walibi Maître Bromptoniste
Sujet: Re: Brompton Users - Questionnaire Ven 25 Jan 2008, 11:31
Q. Which Brompton model number do you currently own? E.g. M-type... M2L-X • S6R titanium and M6R
Q. How long for? Please indicate with a X... • 0-6 months X • 6 months – 1 year • 1-2 years • 2-5 years • 5 years +
None
I do have tools
No
Both
Elliot
lcd Invité de marque
Nombre de messages : 409 Age : 44 Localisation : Enghien, Belgique Mon Brompton: : M6L gris/noir et M6R noir/gris Date d'inscription : 19/11/2007
Sujet: Re: Brompton Users - Questionnaire Ven 25 Jan 2008, 12:22
Hello,
Q. What problems or breakdowns have you had with your Brompton cycle? Puncture Q. Did you own the tools to fix these problems? Yes Q. If you did, did you carry them on your bike in case of emergency break downs? Yes Q. Do you perform maintenance on your Brompton yourself or take it to a bike shop? Bike shop Q. If you do perform it yourself, how often do you do it? / Q. What tools do you require to do the work? / Q. What is the hardest maintenance or most time consuming task? / Q. How often do you get a puncture? Once in about 2 months Q. What Brompton accessories do you own? E.g. front panniers Front pannier, saddle bag
Elliot
Vinvin Héros sportif
Sujet: Re: Brompton Users - Questionnaire Ven 25 Jan 2008, 19:57
[quote="elliot tanner"] Q. Which Brompton model number do you currently own? E.g. M-type... M2L-X • S-Type... • C-Type... • M-Type...M3L • P-type... • Other...
Q. How long for? Please indicate with a X... • 0-6 months • 6 months – 1 year • 1-2 years • 2-5 years X • 5 years +
Q. What problems or breakdowns have you had with your Brompton cycle? Puncture, rear derailleur tension Q. Did you own the tools to fix these problems? yes Q. If you did, did you carry them on your bike in case of emergency break downs? yes anti-puncture bomb, multifuction-keys, take-off tyre Q. Do you perform maintenance on your Brompton yourself or take it to a bike shop? myself Q. If you do perform it yourself, how often do you do it? monthly
Q. What tools do you require to do the work? Multifunction tool, rag, lubricant, soap
Q. What is the hardest maintenance or most time consuming task? take-off rear wheel
Q. How often do you get a puncture? No, 1 with yellow tyres, no since 2 years, thanks to Marathon Tyres inflated to 5bars pressure maxi
Q. What Brompton accessories do you own? E.g. front panniers S-bag, rollers wheels, brooks saddle aged, Schwalbe Marathon tyres, Reelight, Folding basket set
Why the easy-wheels are not installed in the basic-model?
Why are there no model with front suspension (ex. Pantour)?
